Correlation spreading in quantum lattice models with variable-range interactions - Thèse de l'Institut d'Optique Graduate School Accéder directement au contenu
Thèse Année : 2019
Propagation de corrélations dans des modèles quantiques sur réseau pour des interactions à portée variable
In this thesis, we have investigated the spreading of quantum correlations in isolated lattice models with short- or long-range interactions driven far from equilibrium via sudden global quenches. A main motivation for this research topic was to shed new light on the conflicting results in the literature concerning the scaling law of the correlation edge, its lack of universality and the incompleteness of the existing physical pictures to fully characterize the propagation of quantum correlations. To do so, we have presented a general theoretical approach relying on a quasiparticle theory. The latter has permitted to unveil a generic expression for the equal-time connected correlation functions valid both for short-range and long-range interacting particle and spin lattice models on a hypercubic lattice. Relying on stationary phase arguments, we have shown that its causality cone displays a universal twofold structure consisting of a correlation edge and a series of local extrema defining the outer and inner structure of the space-time correlations. For short-range interactions, the motion of each structure is ballistic and the associated spreading velocities are related to the group and phase velocites of the quasiparticle dispersion relation of the post-quench Hamiltonian. For long-range interactions of the form 1/|R|^α, the correlation spreading is substantially different due to a possible divergence of group velocity when tuning the power-law exponent α. For a divergent group velocity, extit{ie.} the quasi-local regime, we have presented evidence of a universal algebraic structure for the causality cone. While, the correlation edge motion has been found to be always slower than ballistic, the local extrema propagate faster than ballistically and ballistically for gapless and gapped quantum systems respectively. For the local regime implying a well-defined group velocity, we have recovered similar scaling laws and spreading velocities than the short-range case for the causality cone of correlations. The previous theoretical predictions have been verified numerically using tensor network techniques within the case study of the short-range Bose-Hubbard chain and the long-range s=1/2 XY and transverse Ising chains.
Dans cette thèse, nous nous sommes intéressés à la propagation hors équilibre de corrélations dans des modèles quantiques sur réseau. L'objectif principal a été de comprendre comment se propage l'information dans un système quantique corrélé et d'expliquer notamment des résultats a priori contradictoires dans la littérature. Pour ce faire, nous avons employé une approche combinant des études analytiques et numériques. En ce qui concerne l'approche analytique, celle-ci est basée sur une théorie de quasiparticules et a permis de dévoiler une expression générique des fonctions de corrélation pour des systèmes quantiques de particules ou de spins interagissant à courte ou longue portée sur un réseau hypercubique. En utilisant la méthode de phase stationnaire, nous avons montré que la région causale de ces corrélations présente une structure double universelle. Cette dernière est composéenon seulement d'une borne mais également d'extrema locaux dans son voisinage définissant la partie externe et interne des corrélations résolues en temps et distance respectivement. Dans le cas d'interactions de courte portée, nous avons prouvé que les deux structures se propagent ballistiquement avec des vitesses généralement différentes et reliées à la vitesse de groupe et de phase du spectre d'excitation du Hamiltonien après quench. Pour des interactions de longue portée de type loi de puissance, les lois d'échelle peuvent être sensiblement modifiées dues à une possible divergence de la vitesse de groupe. Pour ce cas spécifique correspondant au régime dit quasi-local, une double structure aux lois d'échelle algébriques a été présentée.Bien que la borne des corrélations se propage toujours moins rapidement que ballistiquement, les extrema locaux se propagent plus rapidement que ballistiquement et ballistiquement pour des systèmes quantiques non gappés et gappés respectivement. Cependant pour le régime local caractérisé par une valeur maximale bien définie de la vitesse de groupe et impliquant une décroissance rapide des interactions de longue portée, nous avons retrouvé un comportement similaire au cas d'interactions de courte portée pour la propagation des corrélations. Afin de vérifier nos prédictions théoriques, des simulations numériques basées sur des techniques de réseaux de tenseurs ont été effectuées pour différents systèmes quantiques à savoir le modèle de Bose-Hubbard ainsi que les modèles de spins XY et d'Ising transverse.
80760_DESPRES_2019_archivage.pdf (8.53 Mo) Télécharger le fichier
tel-02921450 , version 1 (25-08-2020)
  • HAL Id : tel-02921450 , version 1
Julien Despres. Correlation spreading in quantum lattice models with variable-range interactions. Optics [physics.optics]. Université Paris Saclay (COmUE), 2019. English. ⟨NNT : 2019SACLO018⟩. ⟨tel-02921450⟩
169 Consultations
213 Téléchargements
