Certification of Breadth-First Algorithms by Extraction - Assistance à la Certification d’Applications DIstribuées et Embarquées Accéder directement au contenu
By using pointers, breadth-first algorithms are very easy to implement efficiently in imperative languages. Implementing them with the same bounds on execution time in purely functional style can be challenging, as explained in Okasaki’s paper at ICFP 2000 that even restricts the problem to binary trees but considers numbering instead of just traversal. Okasaki’s solution is modular and factors out the problem of implementing queues (FIFOs) with worst-case constant time operations. We certify those FIFO-based breadth-first algorithms on binary trees by extracting them from fully specified Coq terms, given an axiomatic description of FIFOs. In addition, we axiomatically characterize the strict and total order on branches that captures the nature of breadth-first traversal and propose alternative characterizations of breadth-first traversal of forests. We also propose efficient certified implementations of FIFOs by extraction, either with pairs of lists (with amortized constant time operations) or triples of lazy lists (with worst-case constant time operations), thus getting from extraction certified breadth-first algorithms with the optimal bounds on execution time.
LarcheyWendling_Matthes-MPC2019.pdf (729.92 Ko) Télécharger le fichier
hal-02333423 , version 1 (18-11-2019)
Dominique Larchey-Wendling, Ralph Matthes. Certification of Breadth-First Algorithms by Extraction. 13th International Conference on Mathematics of Program Construction, MPC 2019, Oct 2019, Porto, Portugal. pp.45-75, ⟨10.1007/978-3-030-33636-3_3⟩. ⟨hal-02333423⟩
165 Consultations
130 Téléchargements
