Implementing Security Protocol Monitors - Logique, Interaction, Langue et Calcul Accéder directement au contenu
Cryptographic protocols are often specified by narrations, i.e., finite sequences of message exchanges that show the intended execution of the protocol. Another use of narrations is to describe attacks. We propose in this paper to compile, when possible, attack describing narrations into a set of tests that honest participants can perform to exclude these executions. These tests can be implemented in monitors to protect existing implementations from rogue behaviour.
eptcs.pdf (157.36 Ko) Télécharger le fichier
hal-03463789 , version 1 (02-12-2021)
Yannick Chevalier, Michaël Rusinowitch. Implementing Security Protocol Monitors. SCSS 2021 - 9th International Symposium on Symbolic Computation in Software Science, Sep 2021, Linz/virtual, Austria. pp.22-34, ⟨10.4204/EPTCS.342.3⟩. ⟨hal-03463789⟩
40 Consultations
43 Téléchargements
