LandCover2RDF: an API for computing the land cover of a geographical area and generating the RDF graph - Méthodes et Ingénierie des Langues, des Ontologies et du Discours Accéder directement au contenu
Poster De Conférence Année : 2020
Land cover classifications are recognised to be a fundamental source of data to characterise Earth surface and to support change detection analyses. Land cover maps have been produced from different sources as a result of massive time-series image processing. This paper proposes a REST API that allows for computing the percentage of Land Cover classes of a geographic area using such a map. The computed data is then represented as RDF triples based on an ontology dedicated to this kind of data together with their temporal and spatial dimensions. We illustrate the use of the API to study the evolution of Land Cover on a specific geographical area.
Dorne_26422.pdf (466.82 Ko) Télécharger le fichier
hal-02938617 , version 1 (15-09-2020)
Jordane Dorne, Nathalie Aussenac-Gilles, Catherine Comparot, Romain Hugues, Cassia Trojahn dos Santos. LandCover2RDF: an API for computing the land cover of a geographical area and generating the RDF graph. Andreas Harth; Valentina Presutti; Raphaël Troncy; Maribel Acosta; Axel Polleres; Javier D. Fernández; Olaf Hartig; Katja Hose; Michael Cochez. Extended Semantic Web Conference (ESWC 2020), Jun 2020, Heraklion, Greece. Springer, The Semantic Web: ESWC 2020 Satellite Events: ESWC 2020 Satellite Events, Heraklion, Crete, Greece, May 31 – June 4, 2020, Revised Selected Papers ; ISBN: 978-3-030-62326-5, 12124, pp.73-78, 2020, Lecture Notes in Computer Science book series (LNCS). ⟨10.1007/978-3-030-62327-2_13⟩. ⟨hal-02938617⟩
137 Consultations
103 Téléchargements
