A Mereological System for Informational Templates - Méthodes et Ingénierie des Langues, des Ontologies et du Discours Accéder directement au contenu
We propose an axiomatic ontological framework for informational templates based on former works on slot-mereology. Templates and their parts can be filled by information content entities, but can exist even if unfilled. Thus, we represent templates as slots that can themselves have slots, where the "slot of" relation between slots can be interpreted as a parthood relation. Some slots of a slot are mandatory and need to be filled for the parent slot to be filled, whereas others are optional and do not have this restriction. The structure of a filler is also described by slots of a different nature. We discuss how parthood between slots can be connected with parthood between their fillers.
2022 - Barton.Tarbouriech.Vieu.Ethier - Mereology informational templates.pdf (545.28 Ko) Télécharger le fichier
hal-03919157 , version 1 (02-01-2023)
Paternité
  • HAL Id : hal-03919157 , version 1
Adrien Barton, Cédric Tarbouriech, Laure Vieu, Jean-François Ethier. A Mereological System for Informational Templates. 6th Workshop on Foundational Ontology (FOUST 2022) @ The 8th Joint Ontology Workshops (JOWO 2022), International Association for Ontology and its Applications (IAOA), Aug 2022, Jönköping, Sweden. paper 4. ⟨hal-03919157⟩
56 Consultations
24 Téléchargements
