Latest full text publications
Julien Lesouple, Barbara Pilastre, Yoann Altmann, Jean-Yves Tourneret. Estimation du centre et du rayon d'une hypersphère à l'aide d'une loi a priori de Von Mises-Fisher et d'un algorithme EM. XXVIIIème Colloque Francophone de Traitement du Signal et des Images (GRETSI 2022), Sep 2022, Nancy, France. ⟨hal-03693945v2⟩
Lorena Leon Arencibia, Herwig Wendt, Jean-Yves Tourneret, Patrice Abry. Estimation du paramètre de multifractalité : régression linéaire, maximum de vraisemblance ou inférence Bayésienne ?. XXVIIIème Colloque Francophone de Traitement du Signal et des Images (GRETSI 2022), Sep 2022, Nancy, France. pp.1-4. ⟨hal-03850442v2⟩
Oliver Orejola, Gustavo Didier, Patrice Abry, Herwig Wendt. Hurst multimodality detection based on large wavelet random matrices. 30th European Conference on Signal Processing (EUSIPCO 2022), European Association for Signal Processing (EURASIP), Aug 2022, Belgrade, Serbia. pp.2131-2135. ⟨hal-03850437v2⟩
Lorena Leon Arencibia, Herwig Wendt, Jean-Yves Tourneret, Patrice Abry. A Comparison of Bayesian Estimators for the Parameters of the Bivariate Multifractal Spectrum. 30th European Signal Processing Conference (EUSIPCO 2022), European Association for Signal Processing (EURASIP), Aug 2022, Belgrade, Serbia. pp.1930-1934, ⟨10.23919/EUSIPCO54536.2021.9616049⟩. ⟨hal-03735506⟩
Documents
274
Distribution per document type
