Coupling radiative, conductive and convective heat-transfers in a single Monte Carlo algorithm: a general theoretical framework for linear situations - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
Jean-Luc Amestoy
  • Function : Author
  • PersonId : 1175877
Jean-Jacques Bézian
Jean-François Cornet
Christophe Coustet
Jérémi Dauchet
Sébastien Dutour
Vincent Eymet
Vincent Forest
  • Function : Author
Jacques Lluc
  • Function : Author
  • PersonId : 1174977
Benjamin Piaud
  • Function : Author
  • PersonId : 1111911
Gisèle Roques
  • Function : Author
  • PersonId : 1175879
Maxime Roger
Thomas Saez
  • Function : Author
  • PersonId : 1175880
Thomas Vourc’h
Daniel Yaacoub
  • Function : Author
It was recently shown that radiation, conduction and convection can be combined within a single Monte Carlo algorithm and that such an algorithm immediately benefits from state-of-the-art computer-graphics advances when dealing with complex geometries. The theoretical foundations that make this coupling possible are fully exposed for the first time, supporting the intuitive pictures of continuous thermal paths that run through the different physics at work. First, the theoretical frameworks of propagators and Green’s functions are used to demonstrate that a coupled model involving different physical phenomena can be probabilized. Second, they are extended and made operational using the Feynman-Kac theory and stochastic processes. Finally, the theoretical framework is supported by a new proposal for an approximation of coupled Brownian trajectories compatible with the algorithmic design required by ray-tracing acceleration techniques in highly refined geometry.
main_fr.pdf (1.27 Mo) Télécharger le fichier
Dates and versions
hal-03819157 , version 1 (18-10-2022)
Identifiers
  • HAL Id : hal-03819157 , version 1
Cite
Jean-Marc Tregan, Jean-Luc Amestoy, Mégane Bati, Jean-Jacques Bézian, Stéphane Blanco, et al.. Coupling radiative, conductive and convective heat-transfers in a single Monte Carlo algorithm: a general theoretical framework for linear situations. 2022. ⟨hal-03819157⟩
329 View
52 Download
Share
