Optimized algorithm to reduce the near-field measurement time on FPGA device - IRT Saint Exupéry - Institut de Recherche Technologique Accéder directement au contenu
This paper presents a sequential adaptive sampling algorithm in order to reduce the measurement time of near-field scan. The originality of this approach is to use a deterministic mesh swept according to a sequential progressive adaptive algorithm that defines whether a point must be captured or not. All the proposed algorithm parameters are set according to spatial field characteristics and the measurement setup. This approach is validated on the measurement of the magnetic field produced in near-field region by a FPGA device.
Electronique
Optimize algorithm to reduce the near field measurement time on FPGA_final.pdf (522.14 Ko) Télécharger le fichier
hal-02319472 , version 1 (18-10-2019)
  • HAL Id : hal-02319472 , version 1
Sebastien Serpaud, Alexandre Boyer, Sonia Ben Dhia. Optimized algorithm to reduce the near-field measurement time on FPGA device. 12th International Workshop on the Electromagnetic Compatibility of Integrated Circuits (EMC Compo 2019), Oct 2019, Haining, China. ⟨hal-02319472⟩
33 Consultations
11 Téléchargements
