Innovative conductive polymer composite coating for aircrafts lightning strike protection - IRT Saint Exupéry - Institut de Recherche Technologique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Polymer Science Année : 2019
A new kind of high electrical conductive epoxy coating with low filler rate was investigated for lightning strike protection (LSP) of carbon fiber reinforced polymer (CFRP). The coating without CFRP substrate was firstly studied. The influence of silver submicronic wires (AgSWs) with a high aspect ratio on the electrical behavior is observed; that is, the electrical resistivity evolution, the current density value, and the electrical conduction mechanisms as function of temperature. The preponderant electrical conduction mechanism is an Ohmic behavior. The higher level of conductivity obtained is 5.5 × 105 S m−1 for 9% vol of AgSWs. Lightning strike tests were carried out on an epoxy/AgSWs coating filled with 8% in volume (74 gsm) and deposited on a CFRP. The ultrasonic testing after lightning strike on coated CFRP shows no structural delamination and demonstrates the interest of this new route for an efficient LSP.
Bedel_25087.pdf (2.1 Mo) Télécharger le fichier
hal-02364732 , version 1 (15-11-2019)
Vincent Bedel, Antoine Lonjon, Eric Dantras, Michel Bouquet. Innovative conductive polymer composite coating for aircrafts lightning strike protection. Journal of Applied Polymer Science, 2019, 137, pp.1-11. ⟨10.1002/app.48700⟩. ⟨hal-02364732⟩
54 Consultations
157 Téléchargements
