A time-stepping method for stiff multibody dynamics with contact and friction, International J. Numer. Methods Engineering, vol.55, pp.753-784, 2002. ,
Does the nervous system use equilibrium-point control to guide single and multiple joint movements?, Behavioral and Brain Sciences, vol.15, pp.603-613, 1992. ,
The central nervous system stabilizes unstable dynamics by learning optimal impedance, Nature, vol.414, pp.446-449, 2001. ,
A computational framework for simulating and analyzing human and animal movement, Computing in Science and Engineering, 2000. ,
Handrix: Animating the human hand, ACM SIGGRAPH Symposium on Computer Animation, pp.110-119, 2003. ,
Once More on the Equilibrium-Point Hypothesis (?? Model) for Motor Control, Journal of Motor Behavior, vol.62, issue.1, pp.17-54, 1986. ,
DOI : 10.1080/00222895.1986.10735369
Human arm stiffness and equilibrium-point trajectory during multi-joint movement, Biological Cybernetics, vol.76, pp.163-171, 1997. ,
Identification of the mechanical impedance at the human finger tip, Journal of biomechanical engineering, vol.119, issue.1, pp.109-114, 1997. ,
System identificaiton of the human hand grasping a haptic knob, Proceedings of the 10th Symposium on Haptic Interfaces for Virtual Environments and Teleoperator Systems (HAPTICS'02), 2002. ,
Adapting simulated behaviors for new characters, SIGGRAPH '97: Proceedings of the 24th annual conference on Computer graphics and interactive techniques, pp.153-162, 1997. ,
Knowing when to put your foot down, SI3D '06: Proceedings of the 2006 symposium on Interactive 3D graphics and games, pp.49-53, 2006. ,
Characterizing the human wrist for improved haptic interaction, Proc. ASME Int. Mechanical Engineering Congress and Exposition, 2003. ,
Modeling deformable human hands from medical images, ACM SIGGRAPH Symposium on Computer Animation, pp.357-365, 2004. ,
Learning physics-based motion style with nonlinear inverse optimization, ACM Trans. Graph, vol.24, issue.3, pp.1071-1081, 2005. ,
Implementation of multi-rigid-body dynamics within a robotic grasping simulator, 2003 IEEE International Conference on Robotics and Automation (Cat. No.03CH37422), pp.2262-2268, 2003. ,
DOI : 10.1109/ROBOT.2003.1241930
Characterization of multijoint finger stiffness: dependence on finger posture and force direction, IEEE Transactions on Biomedical Engineering, vol.45, issue.11, pp.1363-1375, 1998. ,
Modeling tension and relaxation for computer animation, SCA '02: Proceedings of the 2002 ACM SIGGRAPH/Eurographics symposium on Computer animation, pp.81-88, 2002. ,
Quasi-rigid objects in contact, SCA '04: Proceedings of the 2004 ACM SIGGRAPH/Eurographics Symposium on Computer Animation, pp.109-119, 2004. ,
Physically based grasping control from example, SCA '05: Proceedings of the 2005 ACM SIGGRAPH/Eurographics Symposium on Computer Animation, pp.311-318, 2005. ,
Physically based motion transformation, SIGGRAPH '99: Proceedings of the 26th annual conference on Computer graphics and interactive techniques, pp.11-20, 1999. ,
Stability in force-production tasks, Journal of Motor Behavior, vol.33, issue.2, pp.193-204, 2001. ,
Hybrid control for interactive character animation, 11th Pacific Conference onComputer Graphics and Applications, 2003. Proceedings., p.455, 2003. ,
DOI : 10.1109/PCCGA.2003.1238294
An implicit time-stepping scheme for rigid body dynamics with inelastic collisions and coulomb friction, International J. Numer. Methods Engineering, vol.39, pp.2673-2691, 1996. ,
Finite volume methods for the simulation of skeletal muscle, SCA '03: Proceedings of the 2003 ACM SIGGRAPH/Eurographics Symposium on Computer Animation, Eurographics Association, pp.68-74, 2003. ,
Helping hand: an anatomically accurate inverse dynamics solution for unconstrained hand motion, SCA '05: Proceedings of the 2005 ACM SIGGRAPH/Eurographics Symposium on Computer Animation, pp.319-328, 2005. ,
A robust ensemble data method for identification of human joint mechanical properties during movement, IEEE Transactions on Biomedical Engineering, vol.46, issue.4, pp.409-419, 1999. ,
Motion perturbation based on simple neuromotor control models, Proceedings of the 11th Pacific Conference on Computer Graphics and Applications, pp.445-449, 2003. ,
Motion capture-driven simulations that hit and react, SCA '02: Proceedings of the 2002 ACM SIGGRAPH/Eurographics symposium on Computer animation, pp.89-96, 2002. ,
Dynamic response for motion capture animation, ACM Trans. Graph, vol.24, issue.3, pp.697-701, 2005. ,
