Pressure-driven actuators based on dry-films lamination - Équipe Ingénierie pour les sciences du vivant Accéder directement au contenu
Poster De Conférence Année : 2017
Pressure-driven microfluidic valves have been extensively used since their apparition in 2000, mainly using PDMS as their constitutive material. While PDMS valves processing is well suited to rapid prototyping, it is not optimal for large-scale manufacturing. We offer an alternative approach based on the double exposure of laminated DF-1000 Series dry-films. Every layer is processed by conventionnal photolithography. It allows excellent alignment precision and a mass-production compatible workflow at the wafer scale level. This work was partly supported by the french RENATECH network.
2017 - Flow17 poster - FINAL.pdf (4.88 Mo) Télécharger le fichier
hal-02470130 , version 1 (07-02-2020)
  • HAL Id : hal-02470130 , version 1
Vincent Raimbault, Laurent Malaquin, Rémi Courson. Pressure-driven actuators based on dry-films lamination. Flow17 for Microfluidic, Jul 2017, Paris, France. , 2017. ⟨hal-02470130⟩
141 Consultations
2 Téléchargements
