Designing objective quality metrics for panoramic videos based on human perception - Systèmes Interactifs et Cognitifs Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The creation of high quality panoramic videos for immersive VR content is commonly done using a rig with multiple cameras covering the required scene. Unfortunately, this setup introduces both spatial and temporal artifacts due to the difference in optical centers as well as imperfect synchronization of cameras. Traditional image quality metrics are inadequate for describing geometric distortions in panoramic videos. In this paper, we propose an objective quality assessment approach for calculating these distortions based on optical flow coupled with an existing salience detection model. Our approach is validated with a human-centered study using error annotations and eye-tracking. Preliminary results indicate a good correlation between errors detected by the algorithm and human perception of errors.
imvip2018_camera_ready_paper31.pdf (12.3 Mo) Télécharger le fichier
hal-01849043 , version 1 (25-07-2018)
  • HAL Id : hal-01849043 , version 1
Sandra Nabil, Raffaella Balzarini, Frédéric Devernay, James L. Crowley. Designing objective quality metrics for panoramic videos based on human perception. IMVIP 2018 - Irish Machine Vision and Image Processing Conference, Aug 2018, Belfast, United Kingdom. pp.1-4. ⟨hal-01849043⟩
591 Consultations
139 Téléchargements
