Conference papers
CO/DA: Live-Coding Movement-Sound Interactions for Dance Improvisation
Jules Françoise 1 Sarah Fdili Alaoui 2 Yves Candau 3
1 AMI - Architectures et Modèles pour l'Interaction
LISN - Laboratoire Interdisciplinaire des Sciences du Numérique, IaH - Interaction avec l'Humain
2 EX-SITU - Extreme Situated Interaction
Inria Saclay - Ile de France, LISN - Laboratoire Interdisciplinaire des Sciences du Numérique, IaH - Interaction avec l'Humain
Abstract : We present a performance-led inquiry that involved a live coder programming movement-based interactive sound and two dance improvisers. During two years of collaboration, we developed a joint improvisation practice where the interactions between the dancers’ movement and the sound feedback are programmed on the fly through live coding and movement sensing. To that end, we designed a new live coding environment called CO/DA that facilitates the real-time manipulation of continuous streams of the dancers’ motion data for interactive sound synthesis. Through an autoethnographic inquiry, we describe our practice of sound and movement improvisation where live coding dynamically changes how the dancers’ movements generate sound, which in turn influences the dancers’ improvisation. We then discuss the value, potential and challenges of our dance/code improvisation practice, along with its implications as a design method.
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-03688840
Contributor : Jules Françoise Connect in order to contact the contributor
Submitted on : Tuesday, June 7, 2022 - 10:32:13 AM
Last modification on : Friday, August 5, 2022 - 9:27:34 AM
File
coda.pdf
Publication funded by an institution
Identifiers
Citation
Jules Françoise, Sarah Fdili Alaoui, Yves Candau. CO/DA: Live-Coding Movement-Sound Interactions for Dance Improvisation. CHI '22: CHI Conference on Human Factors in Computing Systems, Apr 2022, New Orleans LA USA, France. pp.1-13, ⟨10.1145/3491102.3501916⟩. ⟨hal-03688840⟩
Share
Metrics
Record views
13
Files downloads
3
