Frame-based Elastic Models - EVASION Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2011
We present a new type of deformable model which combines the realism of physically based continuum mechanics models and the usability of frame- based skinning methods. The degrees of freedom are coordinate frames. In contrast with traditional skinning, frame positions are not scripted but move in reaction to internal body forces. The displacement field is smoothly in- terpolated using dual quaternion blending. The deformation gradient and its derivatives are computed at each sample point of a deformed object and used in the equations of Lagrangian mechanics to achieve physical realism. This allows easy and very intuitive definition of the degrees of freedom of the deformable object. The meshless discretization allows on-the-fly inser- tion of frames to create local deformations where needed. We formulate the dynamics of these models in detail and describe some pre-computations that can be used for speed. We show that our method is effective for behaviors ranging from simple unimodal deformations to complex realistic deforma- tions comparable with Finite Element simulations. To encourage its use, the software will be freely available in the simulation platform SOFA.
main.pdf (1.11 Mo) Télécharger le fichier
video494.avi (7.72 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
inria-00589199 , version 1 (27-04-2011)
inria-00589199 , version 2 (17-12-2012)
Benjamin Gilles, Guillaume Bousquet, François Faure, Dinesh Pai. Frame-based Elastic Models. ACM Transactions on Graphics, 2011, 30 (2), pp.Article No. 15. ⟨10.1145/1944846.1944855⟩. ⟨inria-00589199v2⟩
739 Consultations
4168 Téléchargements
