Star-Shaped Metrics for Mechanical Metamaterial Design - IMAGINE Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2019
We present a method for designing mechanical metamaterials based on the novel concept of Voronoi diagrams induced by star-shaped metrics. As one of its central advantages, our approach supports interpolation between arbitrary metrics. This capability opens up a rich space of structures with interesting aesthetics and a wide range of mechanical properties, including isotropic, tetragonal, orthotropic, as well as smoothly graded materials. We evaluate our method by creating large sets of example structures, provided as accompanying material. We validate the mechanical properties predicted by simulation through tensile tests on a set of physical prototypes.
paper.pdf (24.8 Mo) Télécharger le fichier
addendum.pdf (52.85 Ko) Télécharger le fichier
hal-02118846 , version 1 (03-05-2019)
Jonàs Martínez, Mélina Skouras, Christian Schumacher, Samuel Hornus, Sylvain Lefebvre, et al.. Star-Shaped Metrics for Mechanical Metamaterial Design. ACM Transactions on Graphics, 2019, 38 (4), pp.Article No. 82 :1-13. ⟨10.1145/3306346.3322989⟩. ⟨hal-02118846⟩
2089 Consultations
1532 Téléchargements
