Local Light Alignment for Multi-Scale Shape Depiction - MAVERICK Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2021
Camille Noûs
Motivated by recent findings in the field of visual perception, we present a novel approach for enhancing shape depiction and perception of surface details. We propose a shading-based technique that relies on locally adjusting the direction of light to account for the different components of materials. Our approach ensures congruence between shape and shading flows, leading to an effective enhancement of the perception of shape and details while impairing neither the lighting nor the appearance of materials. It is formulated in a general way allowing its use for multiple scales enhancement in real-time on the GPU, as well as in global illumination contexts. We also provide artists with fine control over the enhancement at each scale.
nm-EG2021-local_light_alignment.pdf (39.95 Mo) Télécharger le fichier
nm-EG2021-local_light_alignment-shadertoy_demo.pdf (37.18 Ko) Télécharger le fichier
nm-EG2021-local_light_alignment-supplementary_material.pdf (171.04 Mo) Télécharger le fichier
nm-EG2021-local_light_alignment-supplementary_video.mp4 (183.43 Mo) Télécharger le fichier
Format : Figure, Image
Commentaire : enhanced version of the romanesco scene using our approach
Format : Vidéo
hal-03140647 , version 1 (16-02-2021)
hal-03140647 , version 2 (23-03-2021)
Nolan Mestres, Romain Vergne, Camille Noûs, Joëlle Thollot. Local Light Alignment for Multi-Scale Shape Depiction. Computer Graphics Forum, 2021, Eurographics 2021, 40 (2), pp.575-584. ⟨10.1111/cgf.142656⟩. ⟨hal-03140647v2⟩
729 Consultations
147 Téléchargements
