Coherent Mark-based Stylization of 3D Scenes at the Compositing Stage - MAVERICK Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2021
We present a novel temporally coherent stylized rendering technique working entirely at the compositing stage. We first generate a distribution of 3D anchor points using an implicit grid based on the local object positions stored in a G-buffer, hence following object motion. We then draw splats in screen space anchored to these points so as to be motion coherent. To increase the perceived flatness of the style, we adjust the anchor points density using a fractalization mechanism. Sudden changes are prevented by controlling the anchor points opacity and introducing a new order-independent blending function. We demonstrate the versatility of our method by showing a large variety of styles thanks to the freedom offered by the splats content and their attributes that can be controlled by any G-buffer.
main.pdf (93.76 Mo) Télécharger le fichier
representative_eg (1).jpg (167.74 Ko) Télécharger le fichier
supplemental_eg.pdf (72.69 Mo) Télécharger le fichier
Format : Préface
Format : Poster
hal-03143244 , version 1 (16-02-2021)
Maxime Garcia, Romain Vergne, Mohamed-Amine Farhat, Pierre Bénard, C Noûs, et al.. Coherent Mark-based Stylization of 3D Scenes at the Compositing Stage. Computer Graphics Forum, 2021, Eurographics 2021, 40 (2), pp.39-49. ⟨10.1111/cgf.142613⟩. ⟨hal-03143244⟩
996 Consultations
86 Téléchargements
