Abstract : Blast furnace slags are a co-product of the metallurgical industry, used in composite cements (CEM II & III) as a partial substitution for Portland clinker and recognized in particular for their advantages in terms of lowering the heat of hydration, increased durability performance and reduced carbon footprint of concrete. Although achieving ultimate mechanical performance comparable to or better than Portland cement (CEM I), binders offering high levels of slag see the development of their mechanical strength greatly slowed down. This phenomenon is explained by a lower reactivity of the slag which requires "activation" conditions to react properly. There are various additives that accelerate the hardening of cements, among which calcium chloride shows the best performance. The effects of calcium chloride are particularly important during the first days of hydration. However, their use is strongly regulated because of the corrosive effect of chlorine on steels of reinforced concrete. The objectives of the thesis are to study the mechanisms of action of calcium chloride on cement-slag binders during the first days of hydration. A panel of experimental techniques has been used to specifically identify the action of chlorides on slag and cement. Coupled results from XRD-NMR SEM experiments show that calcium chloride causes an accelerated precipitation of portlandite and ettringite, resulting from the increase in the reaction rate of clinker. The start of the slag reaction takes place after about 12 hours, and is not impacted by the calcium chloride. On the other hand, the reaction rate of the slag increases in the presence of the accelerator. The rapid, significant and exclusive formation of Friedel salts in the presence of chloride is observed, replacing sulphated and / or carbonated AFm. Increasing the reaction rate of the anhydrous phases results in the precipitation of additional C-S-H. This formation of Friedel salts and C-S-H causes a faster filling of the porosity and the increase of the mechanical performances.
Résumé : Les laitiers de hauts fourneaux sont un coproduit de l'industrie métallurgique, utilisés dans les ciments composés (CEM II & III) en substitution partielle du clinker portland et reconnus notamment pour leurs avantages en termes d'abaissement de chaleur d'hydratation, d'augmentation des performances de durabilité et de réduction du bilan carbone des bétons. Bien qu'atteignant des performances mécaniques ultimes comparables voire supérieures au ciment portland (CEM I), les liants proposant de forts taux de laitier voient le développement de leur résistance mécanique fortement ralenti. Ce phénomène s'explique par une réactivité plus faible du laitier qui nécessite des conditions "d'activation" pour réagir correctement. Il existe divers additifs ayant pour effet d'accélérer le durcissement des ciments, parmi lesquels le chlorure de calcium montre les meilleures performances. Les effets du chlorure de calcium sont particulièrement importants durant les premiers jours de l'hydratation. Cependant, leur usage est fortement règlementé en raison de l'effet corrosif du chlore sur les aciers du béton armé. Les objectifs de la thèse visent à étudier les mécanismes d'action du chlorure de calcium sur les matrices ciment-laitier durant les premiers jours d'hydratation. Un panel de techniques expérimentales a été utilisé pour identifier spécifiquement l'action des chlorures sur le laitier et le ciment. Des couplages DRX-Analyse d'Images MEB et RMN montrent que le chlorure de calcium entraîne une précipitation accélérée de portlandite et d'ettringite, issus de l'augmentation du taux de réaction du clinker. Le démarrage de la réaction du laitier s'opère après environ 12 heures, et n'est pas impacté par le chlorure de calcium. En revanche, le taux de réaction du laitier augmente en présence de l'accélérateur. On observe la formation rapide, importante et exclusive de Sels de Friedel en présence de chlorure, en remplacement des AFm sulfatés et/ou carbonatés. L'augmentation du taux de réaction des phases anhydres entraîne la précipitation de C-S-H supplémentaire. Cette formation de Sels de Friedel et de C-S-H provoquent un remplissage plus rapide de la porosité et l'augmentation des performances mécaniques.
