Journal articles
Stochastic Model Reduction for robust dynamical characterization of structures with random parameters
Abstract : In this paper, we characterize random eigenspaces with a non-intrusive method based on the decoupling of random eigenvalues from their corresponding random eigenvectors. This method allows us to estimate the first statistical moments of the random eigenvalues of the system with a reduced number of deterministic finite element computations. The originality of this work is to adapt the method used to estimate each random eigenvalue depending on a global accuracy requirement. This allows us to ensure a minimal computational cost. The stochastic model of the structure is thus reduced by exploiting specific properties of random eigenvectors associated with the random eigenfrequencies being sought. An indicator with no additional computation cost is proposed to identify when the method needs to be enhanced. Finally, a simple three-beam frame and an industrial structure illustrate the proposed approach.
Complete list of metadata
Cited literature [53 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01612787
Contributor : Luc Laurent Connect in order to contact the contributor
Submitted on : Sunday, October 8, 2017 - 12:09:41 PM
Last modification on : Friday, November 26, 2021 - 6:06:16 PM
Long-term archiving on: : Tuesday, January 9, 2018 - 12:18:18 PM
File
SMR_HAL.pdf
Distributed under a Creative Commons Attribution - NonCommercial - NoDerivatives 4.0 International License
Identifiers
Collections
Citation
Martin Ghienne, Claude Blanzé, Luc Laurent. Stochastic Model Reduction for robust dynamical characterization of structures with random parameters. Comptes Rendus Mécanique, Elsevier, 2017, 345 (12), pp.844-867. ⟨10.1016/j.crme.2017.09.006⟩. ⟨hal-01612787⟩
Share
Metrics
Les métriques sont temporairement indisponibles
