Journal articles
Multimodal vibration damping of a beam with a periodic array of piezoelectric patches connected to a passive electrical network
Abstract : A multimodal damping strategy is implemented by coupling a beam to its analogue electrical network. This network comes from the direct electromechanical analogy applied to a transverse lattice of point masses that represents the discrete model of a beam. The mechanical and electrical structures are connected together through an array of piezoelectric patches. A discrete and a semi-continuous model are proposed to describe the piezoelectric coupling. Both are based on the transfer matrix formulation and consider a finite number of patches. It is shown that a simple coupling condition gives a network that approximates the modal properties of the beam. A multimodal tuned mass effect is then obtained and a wide-band damping is introduced by choosing a suitable positioning for resistors in the network. The strategy and the models are experimentally validated by coupling a free-free beam to a completely passive network. A multimodal vibration reduction is observed, which proves the efficiency of the control solution and its potential in term of practical implementation.
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01691081
Contributor : Boris Lossouarn Connect in order to contact the contributor
Submitted on : Thursday, March 22, 2018 - 6:35:25 PM
Last modification on : Monday, August 17, 2020 - 5:26:03 PM
Long-term archiving on: : Thursday, September 13, 2018 - 6:44:32 AM
File
lossouarn_hal_SMS-102271.pdf
Identifiers
Collections
Citation
Boris Lossouarn, Jean-François Deü, Mathieu Aucejo. Multimodal vibration damping of a beam with a periodic array of piezoelectric patches connected to a passive electrical network. Smart Materials and Structures, IOP Publishing, 2015, 24 (11), ⟨10.1088/0964-1726/24/11/115037⟩. ⟨hal-01691081⟩
Share
Metrics
Record views
194
Files downloads
399
