Conference papers
Wave propagation in coupled periodic lattices and application to vibration attenuation through a piezoelectric network
Abstract : As described by Brillouin from the 1940's, elastic lattices of point masses can be a suitable representation of continuous structures for the study of wave propagation. By extrapolating the tuned mass damping strategy to lattices of point masses, a multimodal effect is obtained by coupling two structures presenting the same modal characteristics. Consequently, it is theoretically possible to damp vibrations of a mechanical medium thanks to a connection to its discrete electrical equivalent. The coupling between the two structures can be conducted by distributing periodically piezoelectric elements that are linked together with the electrical network. Compared to the more classical independent resonant shunts, this solution stands out from its broadband capabilities and the possibility to design a completely passive system. This concept is numerically and experimentally validated through the study of wave propagation in one-dimensional electromechanical structures.
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01739546
Contributor : Boris Lossouarn Connect in order to contact the contributor
Submitted on : Thursday, March 22, 2018 - 12:00:03 PM
Last modification on : Monday, August 17, 2020 - 5:26:03 PM
Long-term archiving on: : Wednesday, September 12, 2018 - 6:20:10 PM
File
isma2014_paper123_BorisLossoua...
Identifiers
  • HAL Id : hal-01739546, version 1
Collections
Citation
Boris Lossouarn, Jean-François Deü, Mathieu Aucejo. Wave propagation in coupled periodic lattices and application to vibration attenuation through a piezoelectric network. 26th International Conference on Noise and Vibration Engineering, ISMA2014, Sep 2014, Leuven, Belgium. ⟨hal-01739546⟩
Share
Metrics
Record views
120
Files downloads
107
