Conference papers
Stochastic model identification of a bolted joint for the robust characterisation of the vibrational behaviour of light assembled structures
Abstract : Assembled structures involve non-linear phenomena, as contact or friction, localised at each joint interface. In addition, sources of uncertainties are mainly re- sponsible for deviation between the effective behaviour of the structure and results from deterministic simulations. This work aims to provide a pragmatic approach to robustly characterise the vibrational behaviour of an assembled structure considering the joints parameters variability. This approach would be useful for robust design of solutions, such as solutions for damping vibrations, dedicated to assembled structures and taking into account the variability of the real behaviour of each joint. It is based on a non-intrusive approach referred as the Stochastic Model Reduction (SMR) which is used to identify a simple but sufficient stochastic model of bolted joint.
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-01817915
Contributor : Luc Laurent Connect in order to contact the contributor
Submitted on : Monday, June 18, 2018 - 3:00:40 PM
Last modification on : Wednesday, March 24, 2021 - 2:40:02 PM
Identifiers
  • HAL Id : hal-01817915, version 1
Collections
Citation
Martin Ghienne, Luc Laurent, Claude Blanzé. Stochastic model identification of a bolted joint for the robust characterisation of the vibrational behaviour of light assembled structures . 6th European Conference on Computational Mechanics (ECCM 6), Jun 2018, Glasgow, United Kingdom. ⟨hal-01817915⟩
Share
Metrics
Les métriques sont temporairement indisponibles
