Conference papers
Setting Up Plane And Thin Panels With Representative Simply Supported Boundary Conditions : Comparative Results And Applications In Three Laboratories
Abstract : Compared to numerous theoretical studies, the problem of experimentally realizing supported conditions on plane panels has received very little attention. A technique to setup a simply supported rectangular plane panel for laboratory vibroacoustic tests is described. Several application cases are reported, including three panels built in Groupe d'Acoustique de l'Université de Sherbrooke (GAUS, Sherbrooke, Canada), three panels built at Laboratoire de Mécanique des Structures et des Systèmes Couplés (LMSSC, Paris, France) and one at Laboratoire Vibrations Acoustique (LVA, Lyon, France). Covered subjects include vibration and sound radiation under deterministic and random excitations (diffuse acoustic field, turbulent boundary layer), similitude laws and passive control of vibrations using piezoelectric patches or viscoelastic treatments. All obtained results highlight the interest of having access to a laboratory tool that behaves closely to an exact mathematical model, and confirm that such a tool can be reproduced and generalized between laboratories.
Document type :
Conference papers
Complete list of metadata
Cited literature [12 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01922760
Contributor : Laurent Maxit Connect in order to contact the contributor
Submitted on : Wednesday, November 14, 2018 - 5:03:34 PM
Last modification on : Wednesday, February 10, 2021 - 10:32:07 AM
Long-term archiving on: : Friday, February 15, 2019 - 4:33:21 PM
File
Internoise2018_SimplySupported...
Identifiers
  • HAL Id : hal-01922760, version 1
Citation
Olivier Robin, Alain Berry, Noureddine Atalla, Mathieu Aucejo, Boris Lossouarn, et al.. Setting Up Plane And Thin Panels With Representative Simply Supported Boundary Conditions : Comparative Results And Applications In Three Laboratories. Internoise, Aug 2018, Chicago, United States. ⟨hal-01922760⟩
Share
Metrics
Record views
85
Files downloads
131
