Journal articles
A fully passive nonlinear piezoelectric vibration absorber
Abstract : The objective this study is to develop the first fully passive nonlinear piezoelectric tuned vibration absorber (NPTVA). The NPTVA is designed to mitigate a specific resonance of a nonlinear host structure. To avoid the use of synthetic inductors which require external power, closed magnetic circuits in ferrite material realize the large inductance values required by vibration mitigation at low frequencies. The saturation of an additional passive inductor is then exploited to build the nonlinearity in the NPTVA. The performance of the proposed device is demonstrated both numerically and experimentally.
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-02166431
Contributor : Boris Lossouarn Connect in order to contact the contributor
Submitted on : Wednesday, July 3, 2019 - 11:29:55 AM
Last modification on : Monday, August 17, 2020 - 5:26:03 PM
File
paper_philtrans.pdf
Identifiers
Collections
Citation
Boris Lossouarn, Jean-François Deü, Gaëtan Kerschen. A fully passive nonlinear piezoelectric vibration absorber. Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, Royal Society, The, 2018, 376 (2127), pp.20170142. ⟨10.1098/rsta.2017.0142⟩. ⟨hal-02166431⟩
Share
Metrics
Record views
69
Files downloads
196
