Conference papers
Effect of temperature on the tuning of a piezoelectric resonant shunt composed of variable inductance or variable capacitance
Abstract : The piezoelectric resonant shunt is an electromechanical device that can significantly damp mechanical vibrations if it is finely tuned. However, temperature may influence the electrical components of the shunt and the mechanical parameters of the vibrating structure, and deteriorate the damping performance as a consequence. The objective of this work is to describe how inductive and capacitive components can be chosen so that the shunt tuning is maintained in the case of temperature variations. Two solutions of fully passive adaptive shunts are developed, tested and compared. The first solution includes a variable inductance. In contrast, the second solution includes a variable capacitance and intends on keeping the shunt inductance as constant as possible. Experiments validate the concept of a resonant shunt that autonomously adapts to temperature variations.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-02171707
Contributor : Boris Lossouarn Connect in order to contact the contributor
Submitted on : Wednesday, July 3, 2019 - 10:39:10 AM
Last modification on : Thursday, April 15, 2021 - 10:44:01 AM
File
Contribution_451_proceeding_3....
Identifiers
  • HAL Id : hal-02171707, version 1
Collections
Citation
Robin Darleux, Boris Lossouarn, Jean-François Deü. Effect of temperature on the tuning of a piezoelectric resonant shunt composed of variable inductance or variable capacitance. 28th International Conference on Noise and Vibration Engineering, ISMA2018, Sep 2018, Leuven, Belgium. ⟨hal-02171707⟩
Share
Metrics
Record views
31
Files downloads
57
