Journal articles
A simplified method for random vibration analysis of structures with random parameters
Abstract : Piezoelectric patches with adapted electrical circuits or viscoelastic dissipative materials are two solutions particularly adapted to reduce vibration of light structures. To accurately design these solutions, it is necessary to describe precisely the dynamical behaviour of the structure. It may quickly become computationally intensive to describe robustly this behaviour for a structure with nonlinear phenomena, such as contact or friction for bolted structures, and uncertain variations of its parameters. The aim of this work is to propose a non-intrusive reduced stochastic method to characterize robustly the vibrational response of a structure with random parameters. Our goal is to characterize the eigenspace of linear systems with dynamic properties considered as random variables. This method is based on a separation of random aspects from deterministic aspects and allows us to estimate the first central moments of each random eigenfrequency with a single deterministic finite elements computation. The method is applied to a frame with several Young’s moduli modeled as random variables. This example could be expanded to a bolted structure including piezoelectric devices. The method needs to be enhanced when random eigenvalues are closely spaced. An indicator with no additional computational cost is proposed to characterize the ”proximity” of two random eigenvalues.
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-02561342
Contributor : Martin Ghienne Connect in order to contact the contributor
Submitted on : Sunday, May 3, 2020 - 6:51:15 PM
Last modification on : Saturday, May 9, 2020 - 1:14:11 AM
File
Ghienne_2016_J._Phys.__Conf._S...
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Martin Ghienne, Claude Blanzé. A simplified method for random vibration analysis of structures with random parameters. Journal of Physics: Conference Series, IOP Publishing, 2016, ⟨10.1088/1742-6596/744/1/012174⟩. ⟨hal-02561342⟩
Share
Metrics
Les métriques sont temporairement indisponibles
