Conference papers
REAL-TIME 3D AMBISONICS USING FAUST, PROCESSING, PURE DATA, AND OSC
Abstract : This paper presents several digital signal processing (DSP) tools for the real-time synthesis of a 3D sound pressure field using Ambisonics technologies. The spatialization of monophonic signal or the reconstruction of natural 3D recorded sound pressure fields is considered. The DSP required to generate the loudspeaker signals is implemented using the FAUST programming language. FAUST enables and simplifies the compilation of the developed tools on several architectures and on different DSP tool format. In this paper, a focus is made on the near-field filters implementation which allows for the encoding of spherical waves with distance information. The gain variation with distance is also taken into account. The control of the synthesis can be made by software controllers or hardware controllers, such as joystick, by the mean of PURE DATA and OPEN SOUND CONTROL (OSC) messages. A visual feedback tool using the PROCESSING programming language is also presented in the most recent implementation. The aim of this research derives from a larger research project on physically-accurate sound field reproduction for simulators in engineering and industrial applications.
Document type :
Conference papers
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-03162960
Contributor : Dominique Fober Connect in order to contact the contributor
Submitted on : Friday, March 12, 2021 - 9:58:41 AM
Last modification on : Monday, March 15, 2021 - 3:10:02 AM
Identifiers
  • HAL Id : hal-03162960, version 1
Collections
Citation
Pierre Lecomte, Philippe-Aubert Gauthier. REAL-TIME 3D AMBISONICS USING FAUST, PROCESSING, PURE DATA, AND OSC. Proc. of the 18th Int. Conference on Digital Audio Effects (DAFx-15), Nov 2015, Trondheim, Norway. ⟨hal-03162960⟩
Share
Metrics
Les métriques sont temporairement indisponibles
