Journal articles
Vibrational analysis of structures with stochastic interfaces in the medium-frequency range: Experimental validation on a touch screen
Abstract : This paper proposes a dedicated approach and its experimental validation when dealing with structures (including stochastic parameters, such as interface parameters) in medium-frequency vibrations. The first ingredient is the use of a dedicated approach - the Variational Theory of Complex Rays (VTCR) - to solve the medium-frequency problem. The VTCR, which uses two-scale shape functions verifying the dynamic equation and the constitutive relation, can be viewed as a means of expressing the power balance at the different interfaces between substructures. The second ingredient is the use of the Polynomial Chaos Expansion (PCE) to calculate the random response. Since the only uncertain parameters are those which appear in the interface equations (which, in this application, are the complex connection stiffness parameters), this approach leads to very low computation costs. This method is validated on a new kind of touch screen. The simulated mobilities are compared with experimental ones obtained with a laser vibrometer and a good agreement is founded on a large medium-frequency bandwidth.
Document type :
Journal articles
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-03177136
Contributor : Luc Laurent Connect in order to contact the contributor
Submitted on : Thursday, May 6, 2021 - 1:41:23 PM
Last modification on : Tuesday, October 19, 2021 - 4:09:19 PM
Long-term archiving on: : Saturday, August 7, 2021 - 6:55:46 PM
File
IBHGC_JSV_2014_ROUCH.pdf
Identifiers
Citation
Philippe Rouch, Claude Blanzé. Vibrational analysis of structures with stochastic interfaces in the medium-frequency range: Experimental validation on a touch screen. Journal of Sound and Vibration, Elsevier, 2014, 333 (6), pp.1612-1628. ⟨10.1016/j.jsv.2013.11.014⟩. ⟨hal-03177136⟩
Share
Metrics
Les métriques sont temporairement indisponibles
