Conference papers
Experimental investigation of the influence of the mechanical characteristics of the lip on the vibrations of the single reed
Abstract : The effect of lip on the response of single cane reed is studied. In a first part, the real human lip is characterized using a shaker and a impedance head. The measurement is conducted for different lip configuration. Then artificial lips are built and their mechanical impedance are measured. An artificial lip is retained for making experiments conducted on single reeds. The mechanical response of a a reed mounted on a mouthpiece and excited with a loudspeaker is measured using an artificial lip pressed against the reed. The measured transfer functions show a two degree of freedom response which resonance characteristics depend on the lip pressure. For a high lip pressure, the first resonance shows a high damped resonance around 1200 Hz and the second resonance is located around 4000 Hz.
Keywords : reed lip
Document type :
Conference papers
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-03179547
Contributor : Luc Laurent <>
Submitted on : Wednesday, March 24, 2021 - 12:27:59 PM
Last modification on : Friday, April 16, 2021 - 3:28:01 PM
Identifiers
  • HAL Id : hal-03179547, version 1
Collections
Citation
Bruno Gazengel, Thomas Guimezanes, Jean-Pierre Dalmont, Jean-Baptiste Doc, Sylvain Fagart, et al.. Experimental investigation of the influence of the mechanical characteristics of the lip on the vibrations of the single reed. International Symposium on Musical Acoustics, ISMA 2007, Sep 2007, Barcelona, Spain. ⟨hal-03179547⟩
Share
Metrics
Record views
30
