Conference papers
Effect of parametric uncertainties on vibration mitigation of a rod with interconnected piezoelectric patches
Abstract : This work aims to present an analysis of the effect of parametric uncertainties on the vibration control performance of a rod with periodically distributed piezoelectric patches that may be either independently connected to electrical shunt circuits or interconnected through an electrical line of inductors. In both cases, the capacitance of piezoelectric patches are considered as stochastic parameters following a known probability density function distribution. Then, Monte Carlo simulations are performed to evaluate mean values and confidence intervals of the frequency response functions to assess the robustness of each solution and to compare different solutions in terms of nominal and robust performances. The effect of other electrical components, such as circuits resistances, on the robustness is also analyzed.
Complete list of metadata
https://hal.archives-ouvertes.fr/hal-03196646
Contributor : Boris Lossouarn Connect in order to contact the contributor
Submitted on : Tuesday, April 13, 2021 - 9:08:24 AM
Last modification on : Friday, April 16, 2021 - 3:12:37 AM
Long-term archiving on: : Wednesday, July 14, 2021 - 6:12:17 PM
File
Trindade_Lossouarn_Deu_Icast20...
Identifiers
  • HAL Id : hal-03196646, version 1
Collections
Citation
Marcelo Trindade, Boris Lossouarn, Jean-François Deü. Effect of parametric uncertainties on vibration mitigation of a rod with interconnected piezoelectric patches. 30th International Conference on Adaptive Structures and Technologies, ICAST2019, Oct 2019, Montreal, Canada. ⟨hal-03196646⟩
Share
Metrics
Record views
14
Files downloads
31
