Theses
Modélisation de liaisons flexibles amortissantes en élastomères pour la prédiction du comportement dynamique de systèmes complexes
Abstract : In the context of passive damping, various mechanical systems from the space, aeronautic or auto-mobile industry use elastomer components (shock absorbers, silent blocks, flexible joints...).These materials have frequency, temperature and amplitude dependentcharacteristics. The associated numerical models may become computationally too expensive during an optimization process.The aim of this work is to propose an efficient reduced model of rubber devices that account for the viscoelastic damping and the non-linear pre-stress in the dampers.The first part of this thesis is about how to include the viscoelasticdamping in the reduced model. It starts by using a viscoelastic constitutive relation, based on experimental identification, within the frame of the finite element method to obtain a numerical model of the rubber dampers. A first efficient reduced model is then derived from this FE model by using an original extension of sub-structuring methods in the case of viscoelastic damping.In the second part, the influence of non-linear static pre-stress overthe dynamic behavior and the dissipation in the dampers is studied. An hyper-visco-elastic constitutive relation, linearized in the neighbourhood of a pre-stressed state, is developed. The sub-structuring methods presented in the first part are then upgraded to account for the damping and the geometrical non-linearities in the dampers. Finally, these 2-node reduced models give access to greatly reduced computation times (50 to 100 times faster) and are easy to use for the engineer.
Complete list of metadata
Cited literature [76 references]  Display  Hide  Download
https://tel.archives-ouvertes.fr/tel-01508485
Contributor : Abes Star :  Contact
Submitted on : Friday, April 14, 2017 - 11:32:49 AM
Last modification on : Wednesday, March 20, 2019 - 1:26:43 AM
Long-term archiving on: : Saturday, July 15, 2017 - 12:42:06 PM
File
MORIN_2016.pdf
Version validated by the jury (STAR)
Identifiers
  • HAL Id : tel-01508485, version 1
Collections
Citation
Benjamin Morin. Modélisation de liaisons flexibles amortissantes en élastomères pour la prédiction du comportement dynamique de systèmes complexes. Mécanique des structures [physics.class-ph]. Conservatoire national des arts et metiers - CNAM, 2016. Français. ⟨NNT : 2016CNAM1067⟩. ⟨tel-01508485⟩
Share
Metrics
Les métriques sont temporairement indisponibles
