The Rise-Contact involution on Tamari intervals - Equipe : Graphes, Algorithmes et Combinatoire Accéder directement au contenu
Article Dans Une Revue The Electronic Journal of Combinatorics Année : 2019
Viviane Pons
  • Fonction : Auteur
  • PersonId : 14846
  • IdHAL : vpons
We describe an involution on Tamari intervals and m-Tamari intervals. This involution switches two sets of statistics known as the "rises" and the "contacts" and so proves an open conjecture from Préville-Ratelle on intervals of the m-Tamari lattice.
2019_EJC_RiseContact.pdf (548.34 Ko) Télécharger le fichier
hal-02145887 , version 1 (03-06-2019)
  • HAL Id : hal-02145887 , version 1
Viviane Pons. The Rise-Contact involution on Tamari intervals. The Electronic Journal of Combinatorics, 2019. ⟨hal-02145887⟩
111 Consultations
83 Téléchargements
