WallTokens: Surface Tangibles for Vertical Displays - Laboratoire de recherche en informatique. Équipe: Informatique Centrée sur l'humain Accéder directement au contenu
Emmanuel Courtoux
Caroline Appert
Olivier Chapuis
Tangibles can enrich interaction with digital surfaces. They support eyes-free control or increase awareness of other users' actions. Tangibles have been studied in combination with horizontal surfaces, e.g. tabletops, but not with vertical surfaces, e.g. wall displays. The obvious obstacle is gravity: tangibles cannot be placed on such surfaces without falling. We present WallTokens, easy-to-fabricate tangibles to interact with a vertical surface. A WallToken is a passive token whose footprint is recognized on a tactile surface. It is equipped with a push-handle that controls a suction cup. This makes it easy to switch between sliding the token or attaching it to the wall. We describe how to build such tokens and how to recognize them on a tactile surface. We report on a study showing the benefits of WallTokens for manipulating virtual objects over multi-touch gestures. This project is a step towards enabling tangible interaction in a wall display context.
main-hal.pdf (8.43 Mo) Télécharger le fichier
CHI21-walltokens.mp4 (93.44 Mo) Télécharger le fichier
WTWebsite.zip (5.49 Mo) Télécharger le fichier
hal-03122016 , version 1 (26-01-2021)
Emmanuel Courtoux, Caroline Appert, Olivier Chapuis. WallTokens: Surface Tangibles for Vertical Displays. CHI 2021- International conference on Human factors in computing systems, May 2021, Yokohama ( virtual ), Japan. 13 p., ⟨10.1145/3411764.3445404⟩. ⟨hal-03122016⟩
263 Consultations
169 Téléchargements
