Queries and Updates on Big XML Documents (Extended Abstract) - Publications de l'équipe LaHDAK du LRI Accéder directement au contenu
We present here Andromeda, a system for processing queries and updates on big XML documents. The system exploits static and dynamic partitioning of the input document, so to distribute the computing load among the machines of a Map/Reduce cluster.
sebd.7.pdf (457.34 Ko) Télécharger le fichier
hal-01169269 , version 1 (26-05-2021)
  • HAL Id : hal-01169269 , version 1
Nicole Bidoit, Dario Colazzo, Carlo Sartiani, Alessandro Solimando, Federico Ulliana. Queries and Updates on Big XML Documents (Extended Abstract). SEBD: Sistemi Evoluti per Basi di Dati, Jun 2015, Gaeta, Italy. ⟨hal-01169269⟩
334 Consultations
21 Téléchargements
