Journal articles
Understanding and improving photo-control of ion channels in nociceptors with azobenzene photo-switches
Abstract : Background and Purpose The photo-isomerizable local anaesthetic, quaternary ammonium–azobenzene–quaternary ammonium (QAQ), provides rapid, optical control over pain signalling without involving genetic modification. In darkness or in green light, trans-QAQ blocks voltage-gated K+ and Na+ channels and silences action potentials in pain-sensing neurons. Upon photo-isomerization to cis with near UV light, QAQ blockade is rapidly relieved, restoring neuronal activity. However, the molecular mechanism of cis and trans QAQ blockade is not known. Moreover, the absorption spectrum of QAQ requires UV light for photo-control, precluding use deep inside neural tissue. Experimental Approach Electrophysiology and molecular modelling were used to characterize the binding of cis and trans QAQ to voltage-gated K+ channels and to develop quaternary ammonium–ethylamine–azobenzene–quaternary ammonium (QENAQ), a red-shifted QAQ derivative controlled with visible light. Key Results trans QAQ was sixfold more potent than cis QAQ, in blocking current through Shaker K+ channels. Both isomers were use-dependent, open channel blockers, binding from the cytoplasmic side, but only trans QAQ block was slightly voltage dependent. QENAQ also blocked native K+ and Na+ channels preferentially in the trans state. QENAQ was photo-isomerized to cis with blue light and spontaneously reverted to trans within seconds in darkness, enabling rapid photo-control of action potentials in sensory neurons. Conclusions and Implications Light-switchable local anaesthetics provide a means to non-invasively photo-control pain signalling with high selectivity and fast kinetics. Understanding the mode of action of QAQ and related compounds will help to design of drugs with improved photo-pharmacological properties.
Document type :
Journal articles
Complete list of metadatas
Cited literature [50 references]  Display  Hide  Download
https://hal.sorbonne-universite.fr/hal-01578413
Contributor : Gestionnaire Hal-Upmc <>
Submitted on : Tuesday, August 29, 2017 - 10:54:16 AM
Last modification on : Wednesday, December 9, 2020 - 3:14:15 PM
File
Mourot_2017_Understanding_and....
Identifiers
Citation
Alexandre Mourot, Christian Herold, Michael A Kienzler, Richard H Kramer. Understanding and improving photo-control of ion channels in nociceptors with azobenzene photo-switches. British Journal of Pharmacology, Wiley, 2017, 175 (12), pp.2296-2311. ⟨10.1111/bph.13923⟩. ⟨hal-01578413⟩
Share
Metrics
Record views
852
Files downloads
527
