Classic machine learning algorithms - PaRis AI Research InstitutE Accéder directement au contenu
Chapitre D'ouvrage Année : 2022
In this chapter, we present the main classic machine learning algorithms. A large part of the chapter is devoted to supervised learning algorithms for classification and regression, including nearest-neighbor methods, linear and logistic regressions, support vector machines and tree-based algorithms. We also describe the problem of overfitting as well as strategies to overcome it. We finally provide a brief overview of unsupervised learning methods, namely for clustering and dimensionality reduction. The chapter does not cover neural networks and deep learning.
Chapter 02 - Final.pdf (4.27 Mo) Télécharger le fichier
hal-03830094 , version 1 (26-10-2022)
hal-03830094 , version 2 (15-11-2022)
hal-03830094 , version 3 (24-05-2023)
hal-03830094 , version 4 (25-01-2024)
Paternité
  • HAL Id : hal-03830094 , version 1
Johann Faouzi, Olivier Colliot. Classic machine learning algorithms. Olivier Colliot. Machine Learning for Brain Disorders, Springer, In press. ⟨hal-03830094v1⟩
197 Consultations
788 Téléchargements
