Validation of an immunochromatographic assay kit for the identification of the Mycobacterium tuberculosis complex. - Institut Pasteur de Madagascar Accéder directement au contenu
Article Dans Une Revue Memórias do Instituto Oswaldo Cruz Année : 2011
The performance of the immunochromatographic assay, SD BIOLINE TB Ag MPT64 RAPID®, was evaluated in Madagascar. Using mouse anti-MPT64 monoclonal antibodies for rapid discrimination between the Mycobacterium tuberculosis complex and nontuberculous mycobacteria, the kit was tested on mycobacteria and other pathogens using conventional methods as the gold standard. The results presented here indicate that this kit has excellent sensitivity (100%) and specificity (100%) compared to standard biochemical detection and can be easily used for the rapid identification of M. tuberculosis complex.
22.pdf (243.98 Ko) Télécharger le fichier
Origine : Publication financée par une institution
pasteur-00836564 , version 1 (12-09-2019)
Paternité
Al-Habib Omar Said Toihir, Voahangy Rasolofo, Samuel Hermas Andrianarisoa, Gabriel Marie Ranjalahy, Herimanana Ramarokoto. Validation of an immunochromatographic assay kit for the identification of the Mycobacterium tuberculosis complex.. Memórias do Instituto Oswaldo Cruz, 2011, 106 (6), pp.777-80. ⟨10.1590/s0074-02762011000600022⟩. ⟨pasteur-00836564⟩
46 Consultations
113 Téléchargements
