Epidémiologie et transmission mère-enfant des entérobactéries productrices de bêta-lactamases à spectre étendu (E-BLSE) à Madagascar. - Institut Pasteur de Madagascar Accéder directement au contenu
Thèse Année : 2018
Epidemiology and mother-to-child transmission of Extended-spectrum ß-lactamase-producing Enterobacteria (ESBL-PE) in Madagascar.
The emergence and spread of antibiotic-resistant bacteria is a concern. Infection caused by multidrug-resistant bacteria (MDR) worsens the prognosis of infected patients and increases the costs associated with their management. Among the MDRs, Gram-negative bacteria (GNB), especially extended-spectrum beta-lactamase-producing Enterobacteriaceae (ESBL-PE) are the most frequently isolated. Antibiotic resistance may have an impact on morbidity and mortality in low- and middle-income countries (LMICs) because of the potential for emergence and spread of antibiotic-resistant bacteria, and the burden of bacterial infections in these countries. However, data on bacterial resistance are scarce or came from the hospital, for the great majority, in LMICs. In these settings, severe neonatal bacterial infections (sepsis, pneumoniae and meningitis) still represent the leading causes of death in newborns. Enterobacteriaceaeare responsible for a great part of these neonatal infections. Thus, investigating the transmission of ESBL-PE in newborns would make it possible to propose prevention strategies. This work was based on the BIRDY program (Bacterial Infections and Antibiotic Resistant Diseases among Young Children in Low-Income Countries). The first objective was to estimate the prevalence of colonization by ESBL-PE in pregnant women in Madagascar as well as the risk factors of this colonization. The results showed an overall colonization prevalence of 18.5% [95% CI 14.5-22.6]. Factors reflecting a higher socioeconomic level such as private access to drinking water and having a house are associated with colonization. The second objective of this work was to study the incidence of ESBL-PE colonization in community-based infants and to identify acquisition risk factors. The results reveal an overall incidence of ESBL-PE acquisition of 10.4 per 1000 newborn-days [95% CI: 8.0; 13.4]. In addition, we found that low birth weight adjusted HR 2.7 [95% CI 1.2; 5.9], cesarean section delivery adjusted HR 3.4 [95% CI 1.7; 7.1], maternal intake of antibiotic at delivery adjusted HR 2.2 [95% CI 1.1; 4.5] were risk factors for the acquisition of ESBL-PE. The third objective was to document neonatal infections. We found an incidence of neonatal infections of 30.6 cases per 1000 live births [95% CI: 23.4; 40.1]. Our results suggest that public health measures should focus on the improvement of pregnancy follow-up and early diagnosis of neonatal infections.
L’émergence et la dissémination des bactéries résistantes aux antibiotiques sont préoccupantes. L’infection causée par les bactéries multi-résistantes (BMR) aggrave le pronostic des malades infectés et augmente les dépenses liées à leur prise en charge. Parmi les BMR, les bactéries à Gram négatif (BGN), plus particulièrement les entérobactéries productrices de béta-lactamase à spectre étendu (E-BLSE) sont les plus fréquemment isolées. La résistance aux antibiotiques pourrait avoir un impact sur la morbidité et la mortalité dans les pays à revenu faible ou intermédiaire (PRFI) en raison du potentiel d’émergence et de diffusion de bactéries résistantes aux antibiotiques, et du fardeau des infections bactériennes dans ces pays. Cependant, les données sur la résistance bactérienne sont rares et très majoritairement hospitalières dans les PRFI. De plus, dans ces pays, les infections bactériennes néonatales sévères (septicémies, pneumonies et méningites) représentent encore les principales causes de décès chez les nouveau-nés. Les entérobactéries sont majoritairement responsables de ces infections néonatales. Ainsi, investiguer la transmission d'E-BLSE chez le nouveau-né permettrait de proposer des stratégies de prévention. Ce travail de recherche s’est appuyé sur le programme BIRDY (Bacterial Infections and antibiotic Resistant Diseases among Young children in low-income countries). Le premier objectif était d’estimer la prévalence de la colonisation par des E-BLSE chez les femmes enceintes à Madagascar ainsi que les facteurs favorisant cette colonisation. Les résultats ont montré une prévalence globale de colonisation de 18.5% [IC à 95% 14.5-22.6]. Des facteurs reflétant un niveau socioéconomique plus élevé comme l’accès privatif à l’eau de boisson et avoir une maison individuelle sont associés à la colonisation. Le second objectif de ce travail était d'étudier l'incidence de la première colonisation par des E-BLSE chez les nouveau-nés en milieu communautaire et d'identifier les facteurs de risque d'acquisition. Les résultats révèlent une incidence globale d'acquisitions d'E-BLSE de 10.4 pour 1000 nouveau-nés-jours [IC à 95% : 8.0; 13.4]. Par ailleurs, nous avons mis en évidence que le faible poids à la naissance HR ajusté 2.7 [IC à 95% 1.2 ; 5.9], l'accouchement par césarienne HR ajusté 3.4 [IC à 95% 1.7 ; 7.1], la prise maternelle d'antibiotique à l'accouchement HR ajusté 2.2 [IC à 95% 1.1 ; 4.5] étaient des facteurs de risque d'acquisition d'E-BLSE. Le troisième objectif était de documenter les infections néonatales. Nous avons trouvé une incidence d'infections néonatales de 30.6 cas pour 1000 naissances vivantes [IC à 95%: 23.4 ; 40.1].Nos résultats montrent que les mesures de santé publique devraient axer sur l’amélioration de la prise en charge de la grossesse et sur le diagnostic précoce des infections néonatales.
75925_HERINDRAINY_2018_archivage.pdf (9.73 Mo) Télécharger le fichier
tel-02078758 , version 1 (25-03-2019)
  • HAL Id : tel-02078758 , version 1
Perlinot Herindrainy. Epidémiologie et transmission mère-enfant des entérobactéries productrices de bêta-lactamases à spectre étendu (E-BLSE) à Madagascar.. Médecine humaine et pathologie. Université Paris Saclay (COmUE), 2018. Français. ⟨NNT : 2018SACLV074⟩. ⟨tel-02078758⟩
771 Consultations
486 Téléchargements
