Book sections
Mixed-Integer Programming Techniques in Distributed MPC Problems
Abstract : This chapter proposes a distributed approach for the resolution of a multi-agent problem under collision and obstacle avoidance conditions. Using hyperplane arrangements and mixed integer programming, we provide an efficient description of the feasible region verifying the avoidance constraints. We exploit geometric properties of hyperplane arrangements and adapt this description to the distributed scheme in order to provide an efficient Model Predictive Control (MPC) solution. Furthermore, we prove constraint validation for a hierarchical ordering of the agents.
Document type :
Book sections
Complete list of metadatas
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-00826633
Contributor : Josiane Dartron <>
Submitted on : Monday, March 16, 2020 - 3:55:52 PM
Last modification on : Monday, December 14, 2020 - 12:38:10 PM
Long-term archiving on: : Wednesday, June 17, 2020 - 2:36:07 PM
File
dist-MIP.pdf
Identifiers
Citation
Ionela Prodan, Florin Stoican, Sorin Olaru, Cristina Stoica, Silviu-Iulian Niculescu. Mixed-Integer Programming Techniques in Distributed MPC Problems. Maestre; José M. and Negenborn; Rudy R. Distributed Model Predictive Control Made Easy, Springer, pp.273-288, 2013, ⟨10.1007/978-94-007-7006-5_17⟩. ⟨hal-00826633⟩
Share
Metrics
Record views
576
Files downloads
338
