Granulats à base de boues de phosphates : transformations thermiques, propriétés physiques et application - Thèses de l'Université de Toulon Accéder directement au contenu
Thèse Année : 2015
Aggregates based phosphate sludge : thermal transformations, physical properties, and application
Phosphate sludge generated from beneficiation plants of Moroccan phosphate rocks was investigated at the range [900-1200°C] by X-ray diffraction, scanning electron microscopy, thermal analysis dilatometric analysis and impedance spectroscopy. Mixtures of the phosphates ludge and amendments such as a swelling clay (up to 30 wt.% of the clay), a kaolinitic clay (up to 40 wt.% of the sludge) and a fly ash (65.5 wt.% of the ash) were investigated and their properties (shrinkage, density, water absorption and compressive strength) were measured as a function of temperature and clay addition. The results showed that gehlénite neoformed from lime of decomposed carbonates and breakdown products of clay minerals in the first mixture while labradorite/anorthite was the only neoformed phase in the other blends. Also fluoroapatite (original mineral) resisted heating until fusion in almost samples. A new approach based on the methodology of the experimental design was adopted to assess the effect of the processing factors on the studied properties. The measured properties were mainly controlled by temperature, and the effect of clay addition was less regular. Considering the mixtures densities lightweight agglomerates can be produced at specific conditions. On the other hand, the release ability of phosphorus by LWAs in the presence ofalfalfa plants has been performed. It was found that due to the release of phosphorus by soil embedded pellets the growth of alfalfa plants improved. The sintering process of blends of phosphate sludge and a naturally occurring clay material (0-30 wt.%) was investigated in the range 650-1100°C by using impedance spectroscopy. The results showed that the sintering process was effective between 750 and 1000°C and occurred by melt flow.
Des agrégats à base des boues de phosphate de la zone de Gantour ( Youssoufia,Maroc) sont cuits à des températures comprises entre 900 et 1200°C, et examinés par différentes techniques (DRX, MEB, analyses thermique et dilatométrique, et spectroscopie d’impédance). Les propriétés physiques des agrégats (retrait, absorption d’eau et résistance à la compression) sont mesurées et corrélées, dans certains cas, aux facteurs expérimentaux(température, temps de cuisson, teneur de l’additif), et ce en utilisant la méthodologie de la recherche expérimentale.Les agrégats amendés à l’argile smectitique sont le siège de formation de la gehlénite. Dans ce cas, la fluorapatite a partiellement résisté au traitement thermique, et a été le siège d’une ségrégation localisée. Les mesures d'impédance ont bien mis en évidence l'étape principale du frittage, lequel s’est produit par écoulement de la masse fondue. En se basant sur les valeurs de la densité, les granulats cuits à 900 et à 1100°C pouvaient bien être considérés comme des agrégats légers.Les études menées sur les agrégats des mélanges : argile kaolinitique-boue, cendre boue,et argile kaolinitique-cendre-boue ont montré la présence de la labradorite, et d’une masse fondue, qui semblait se former, entre autres, de la fusion de la fluorapatite. Par ailleurs,l'utilisation de la méthodologie de la recherche expérimentale a permis d'évaluer le poids des effets des facteurs expérimentaux sur les propriétés physiques des agrégats. Des granulats légers (1,02 < densité < 2,1 g/cm3) et résistants sont préparés avec succès dans les conditions expérimentales adoptées. Les granulats ayant le meilleur rapport résistance / densité sont ceux du mélange ternaire.Concernant le volet application, les résultats ont montré que l’utilisation des agrégats en construction est possible et que l’association d’agrégats légers au sol a permis d’activer la croissance des plants de la luzerne. D’un autre côté, l'absorption du phosphore par les racines(1,45 mg/g maximum) des plantes était meilleure dans le cas du mélange contenant de l’argile.
These_Loutou.pdf (8.21 Mo) Télécharger le fichier
tel-01662477 , version 1 (13-12-2017)
  • HAL Id : tel-01662477 , version 1
Mohamed Loutou. Granulats à base de boues de phosphates : transformations thermiques, propriétés physiques et application. Chimie inorganique. Université de Toulon; Université Cadi Ayyad (Marrakech, Maroc). Faculté des sciences Semlalia, 2015. Français. ⟨NNT : 2015TOUL0016⟩. ⟨tel-01662477⟩
763 Consultations
899 Téléchargements
