Simple examples of perfectly invisible and trapped modes in waveguides - Centre de mathématiques appliquées (CMAP) Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We consider the propagation of waves in a waveguide with Neumann boundary conditions. We work at low wavenumber with only one propagating mode in the leads, all the other modes being evanescent. We assume that the waveguide is symmetric with respect to an axis orthogonal to the longitudinal direction and is endowed with a branch of height L whose width coincides with the wavelength of the propagating modes. In this setting, tuning the parameter L, we prove the existence of simple geometries where the transmission coefficient is equal to one (perfect invisibility). We also show that these geometries, for possibly different values of L, support so called trapped modes (non zero solutions of finite energy of the homogeneous problem) associated with eigenvalues embedded in the continuous spectrum.
ChPa.pdf (791.95 Ko) Télécharger le fichier
hal-01593226 , version 1 (25-09-2017)
hal-01593226 , version 2 (16-03-2018)
hal-01593226 , version 3 (07-12-2018)
  • HAL Id : hal-01593226 , version 2
Lucas Chesnel, Vincent Pagneux. Simple examples of perfectly invisible and trapped modes in waveguides. 2018. ⟨hal-01593226v2⟩
613 Consultations
244 Téléchargements
