Topology optimization of thermal fluid-structure systems using body-fitted meshes and parallel computing - Centre de mathématiques appliquées (CMAP) Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2020
An efficient framework is described for the shape and topology optimization of realistic three-dimensional, weakly-coupled fluid-thermal-mechanical systems. At the theoretical level, the proposed methodology relies on the boundary variation of Hadamard for describing the sensitivity of functions with respect to the domain. From the numerical point of view, three key ingredients are used: (i) a level set based mesh evolution method allowing to describe large deformations of the shape while maintaining an adapted, high-quality mesh of the latter at every stage of the optimization process; (ii) an efficient constrained optimization algorithm which is very well adapted to the infinite-dimensional shape optimization context; (iii) efficient preconditioning techniques for the solution of large finite element systems in a reasonable computational time. The performance of our strategy is illustrated with two examples of coupled physics: respectively fluid-structure interaction and convective heat transfer. Before that, we perform three other test cases, involving a single physics (structural, thermal and aerodynamic design), for comparison purposes and for assessing our various tools: in particular, they prove the ability of the mesh evolution technique to capture very thin bodies or shells in 3D.
threephysics3d_small.pdf (1.82 Mo) Télécharger le fichier
hal-02518207 , version 1 (25-03-2020)
Florian Feppon, Grégoire Allaire, Charles Dapogny, Pierre Jolivet. Topology optimization of thermal fluid-structure systems using body-fitted meshes and parallel computing. Journal of Computational Physics, 2020, 417, pp.109574. ⟨10.1016/j.jcp.2020.109574⟩. ⟨hal-02518207⟩
433 Consultations
1115 Téléchargements
