DIFFERENTIABLE RIGIDITY UNDER RICCI CURVATURE LOWER BOUND - Département de mathématiques Accéder directement au contenu
Article Dans Une Revue Duke Mathematical Journal Année : 2012
Laurent Bessières
  • Fonction : Auteur
  • PersonId : 849281
Gérard Besson
Sylvestre Gallot
  • Fonction : Auteur
  • PersonId : 829331
One proves the following gap theorem, involving the volume and the Ricci curvature : For any integer $n \ge 3$ and $d > 0$, there exists $\epsilon(n, d) > 0 such that the following holds. Let $(X, g_0 )$ be a $n$-dimensional hyperbolic compact manifold with diameter $\le d$ and let $Y$ be a compact manifold which admits a continuous map $f : Y \rightarrow X$ of degree one. Then Y has a metric $g$ such that $Ric_g \geq -(n - 1)g$ and $vol_g (Y ) \leq (1 + \epsilon) vol_{g_0} (X )$ if and only if $f$ is homotopic to a diffeomorphism.
BBCG_Duke (2).pdf (363.56 Ko) Télécharger le fichier
hal-00281855 , version 1 (25-05-2008)
hal-00281855 , version 2 (12-03-2010)
hal-00281855 , version 3 (13-02-2020)
Laurent Bessières, Gérard Besson, Gilles Courtois, Sylvestre Gallot. DIFFERENTIABLE RIGIDITY UNDER RICCI CURVATURE LOWER BOUND. Duke Mathematical Journal, 2012, 161 (1), pp.29-67. ⟨10.1215/00127094-1507272⟩. ⟨hal-00281855v3⟩
225 Consultations
178 Téléchargements
