Construction of multi-soliton solutions for the L2-supercritical gKdV and NLS equations - Département de mathématiques Accéder directement au contenu
Article Dans Une Revue Revista Matemática Iberoamericana Année : 2011
Multi-soliton solutions, i.e. solutions behaving as the sum of N given solitons as $t\to +\infty$, were constructed in previous works for the L2 critical and subcritical (NLS) and (gKdV) equations. In this paper, we extend the construction of multi-soliton solutions to the L2 supercritical case both for (gKdV) and (NLS) equations, using a topological argument to control the direction of instability.
euclid.rmi.1296828835.pdf (279.1 Ko) Télécharger le fichier
hal-00385072 , version 1 (14-02-2020)
Raphaël Côte, Yvan Martel, Frank Merle. Construction of multi-soliton solutions for the L2-supercritical gKdV and NLS equations. Revista Matemática Iberoamericana, 2011, 27 (1), pp.273-302. ⟨10.4171/RMI/636⟩. ⟨hal-00385072⟩
220 Consultations
41 Téléchargements
