On the Convergence of Time Splitting Methods for Quantum Dynamics in the Semiclassical Regime - Département de mathématiques Accéder directement au contenu
Article Dans Une Revue Foundations of Computational Mathematics Année : 2020
François Golse
  • Fonction : Auteur
  • PersonId : 964158
Shi Jin
  • Fonction : Auteur
  • PersonId : 1060698
Thierry Paul
  • Fonction : Auteur
  • PersonId : 878449
  • IdRef : 158973372
By using the pseudo-metric introduced in [F. Golse, T. Paul: Archive for Rational Mech. Anal. 223 (2017) 57-94], which is an analogue of the Wasserstein distance of exponent 2 between a quantum density operator and a classical (phase-space) density, we prove that the convergence of time splitting algorithms for the von Neumann equation of quantum dynamics is uniform in the Planck constant $\hbar$. We obtain explicit uniform in $\hbar$ error estimates for the first order Lie-Trotter, and the second order Strang splitting methods.
TimeSplittingCORR2.pdf (462.53 Ko) Télécharger le fichier
Figurebis.pdf (27.18 Ko) Télécharger le fichier
hal-02567952 , version 1 (08-05-2020)
  • HAL Id : hal-02567952 , version 1
François Golse, Shi Jin, Thierry Paul. On the Convergence of Time Splitting Methods for Quantum Dynamics in the Semiclassical Regime. Foundations of Computational Mathematics, inPress, pp.DOI: 10.1007/s10208-020-09470-z. ⟨hal-02567952⟩
112 Consultations
84 Téléchargements
