Semiclassical Evolution With Low Regularity - Département de mathématiques Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
François Golse
  • Fonction : Auteur
  • PersonId : 838357
Thierry Paul
  • Fonction : Auteur
  • PersonId : 878449
  • IdRef : 158973372
We prove semiclassical estimates for the Schrödinger-von Neumann evolution with $C^{ 1,1}$ potentials and density matrices whose square root have either Wigner functions with low regularity independent of the dimension, or matrix elements between Hermite functions having long range decay. The estimates are settled in different weak topologies and apply to the N body quantum dynamics uniformly in N .
semic21essaifinalhal.pdf (649.7 Ko) Télécharger le fichier
hal-02619489 , version 1 (25-05-2020)
hal-02619489 , version 2 (27-11-2020)
  • HAL Id : hal-02619489 , version 1
François Golse, Thierry Paul. Semiclassical Evolution With Low Regularity. 2020. ⟨hal-02619489v1⟩
147 Consultations
82 Téléchargements
