Fixed-target runtime analysis of the (1 + 1) EA with resampling (student workshop paper) - Laboratoire d'informatique de l'X (LIX) Accéder directement au contenu
We conduct a fixed-target runtime analysis of (1 + 1) EA with resampling on the OneMax and BinVal problems. For OneMax, our fixed-target upper bound refines the previously known bound. Our fixed-target lower bound for OneMax is the first of this kind. We also consider linear functions and show that the traditional approaches via drift analysis cannot easily be extended to yield fixed-target results. However, for the particular case of BinVal, a relatively precise fixed-target bound is obtained.
bl swksp113s2-file1 (1).pdf (708.39 Ko) Télécharger le fichier
hal-02179611 , version 1 (14-01-2020)
Dmitry Vinokurov, Maxim Buzdalov, Arina Buzdalov, Benjamin Doerr, Carola Doerr. Fixed-target runtime analysis of the (1 + 1) EA with resampling (student workshop paper). Genetic and Evolutionary Computation Conference, Companion Material, Jul 2019, Prague, Czech Republic. pp.2068-2071, ⟨10.1145/3319619.3326906⟩. ⟨hal-02179611⟩
79 Consultations
144 Téléchargements
