Microstructure of Powellite-Rich Glass-Ceramics: A Model System for High Level Waste Immobilization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the American Ceramic Society Année : 2012
In this study, we synthesized glass-ceramics from glasses in the system SiO 2-B 2 O 3-Na 2 O-CaO-Al 2 O 3-MoO 3-Gd 2 O 3 by various heat treatments. Glass-ceramics contain only one crystalline phase in the bulk: powellite (namely CaMoO 4). The influence of molybdenum and rare earth contents was studied by SEM and XRD. Heat treatments were optimized to lead to a wide range in size and concentration of powellite. Moreover, the molybdenum content left in residual glasses, calculated by XRD quantification, showed that the residual glasses have a similar composition for a given Gd 2 O 3 content after heat treatments. This work has permitted to synthesize two phase glass-ceramics with constant borosilicate glass matrices and powellite crystals with controlled sizes and concentrations.
Matériaux
powellite-microstructure_vf.pdf (1.13 Mo) Télécharger le fichier
cea-01120954 , version 1 (27-02-2015)
T Taurines, B Boizot. Microstructure of Powellite-Rich Glass-Ceramics: A Model System for High Level Waste Immobilization. Journal of the American Ceramic Society, 2012, 95 (3), pp.1-7. ⟨10.1111/j.1551-2916.2011.05015.x⟩. ⟨cea-01120954⟩
144 Consultations
789 Téléchargements
