Gate-modulated thermopower of disordered nanowires: II. Variable-range hopping regime - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue New Journal of Physics Année : 2014
We study the thermopower of a disordered nanowire in the field effect transistor configuration. After a first paper devoted to the elastic coherent regime (Bosisio R., Fleury G. and Pichard J.-L. 2014 New J. Phys. 16 035004), we consider here the inelastic activated regime taking place at higher temperatures. In the case where charge transport is thermally assisted by phonons (Mott Variable Range Hopping regime), we use the Miller-Abrahams random resistor network model as recently adapted by Jiang et al. for thermoelectric transport. This approach previously used to study the bulk of the nanowire impurity band is extended for studying its edges. In this limit, we show that the typical thermopower is largely enhanced, attaining values larger that 10 kB/e ∼ 1 mV K−1 and exhibiting a non-trivial behaviour as a function of the temperature. A percolation theory by Zvyagin extended to disordered nanowires allows us to account for the main observed edge behaviours of the thermopower.
1403.7475.pdf (741.16 Ko) Télécharger le fichier
cea-01138312 , version 1 (01-04-2015)
Riccardo Bosisio Bosisio, Cosimo Gorini, Geneviève Fleury, Jean-Louis Pichard. Gate-modulated thermopower of disordered nanowires: II. Variable-range hopping regime . New Journal of Physics, 2014, 16, pp.095005. ⟨10.1088/1367-2630/16/9/095005⟩. ⟨cea-01138312⟩
55 Consultations
134 Téléchargements
