MPI detach — Towards automatic asynchronous local completion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Parallel Computing Année : 2022
When aiming for large scale parallel computing, waiting time due to network latency, synchronization, and load imbalance are the primary opponents of high parallel efficiency. A common approach to hide latency with computation is the use of non-blocking communication. In the presence of a consistent load imbalance, synchronization cost is just the visible symptom of the load imbalance. Tasking approaches as in OpenMP, TBB, OmpSs, or C ++20 coroutines promise to expose a higher degree of concurrency, which can be distributed on available execution units and significantly increase load balance. Available MPI non-blocking functionality does not integrate seamlessly into such tasking parallelization. In this work, we present a slim extension of the MPI interface to allow seamless integration of non-blocking communication with available concepts of asynchronous execution in OpenMP and C ++. We furthermore investigate compile-time analysis necessary to transform an application using blocking MPI communication into an application integrating OpenMP tasks with our proposed MPI interface extension.
mpi-detach.pdf (195.23 Ko) Télécharger le fichier
cea-03537990 , version 1 (20-01-2022)
Joachim Protze, Marc-André Hermanns, Matthias S Müller, Van Man Nguyen, Julien Jaeger, et al.. MPI detach — Towards automatic asynchronous local completion. Parallel Computing, 2022, 109, pp.102859. ⟨10.1016/j.parco.2021.102859⟩. ⟨cea-03537990⟩
132 Consultations
400 Téléchargements
